W 210 1998 300TD Stationcar
racingdog
Tilmeldt: 24. maj 2011, 11:58
Indlæg af racingdog »
har gjort det før, men kan bare ikke huske hvordan man slukker service lampen (Svensknøglen) i instrumentbordet, kan nogen hjælpe mig !!!
Re: W 210 1998 300TD Stationcar
nøgle i første stilling - find service display - hold R-tast nede - efter et stykke tid spørger den om den skal nulstille - slip R-tast og tryk og hold denne nede...
Det burde resette service
racingdog
det er ikke sådan man skal gøre, mener det er til en anden model, dette er en W 210 årg. 98
Følgende er taget direkte fra owners manual.
Following a completed A or B service the Mercedes-
Benz Center sets the counter mileage to 10 000 miles
(Canada: 15 000 km).
The counter can also be set by any individual. To do so:
Turn the electronic key in steering lock to position 2.
To call up the trip odometer and main odometer, press
button è or ÿ on the multifunction steering
wheel until the display appears. See page 96.
Press button j or k until the FSS indicator
appears.
Press button J on the instrument cluster for
approximately 4 seconds.
The multifunction display will show the question:
“DO YOU WANT TO RESET SERVICE INTERVAL?
CONFIRM BY PRESSING R”
Press button J on the instrument cluster again for
approximately 4 seconds, and hold until a signal
sounds. The message “SERVICE INTERVAL HAS BEEN
RESET” appears in the multifunction display.
The new service indicator is displayed with the reset
distance of 10 000 miles (Canada 15 000 km).
If the FSS counter was inadvertently reset, have a
Mercedes-Benz Center correct it.
However you choose to set your reference numbers, the
scheduled services as posted in the Service Booklet
must be followed to properly care for your vehicle.
270cdi
Tilmeldt: 8. aug 2010, 18:38
Geografisk sted: Sydsjælland
Indlæg af 270cdi »
Er der overhoved multifunktions rat i en ikke facelift W210 :?: :?
W211/E320CDI V6 Avantgarde
racingdog
nej det er der ikke , der er knappen 0 til venstre, og knappen R lige under speedometerhuset
SLS-AMG
Tilmeldt: 19. feb 2011, 22:40
Indlæg af SLS-AMG »
Nulstilling på instrument:
Tilslut tænding.
Inden for 4 sekunder. Tryk 2 gange på nulstillingstasten til triptælleren inden for 1 sekund. Serviceindikatoren aktiveres nu i 10 sekunder.
Indenfor de 10 sekunder , afbryd tændingen. Serviceindikatoren vises stadig.
Nulstillingstasten til triptælleren aktiveres og holdes inde.
Tilslut tænding.
Hold fortsat nulstillingstasten inde ca. 10 sek. indtil signaltonen lyder og det nye startkilometertal vises på display.
Slip nulstillingstasten.
Afbryd tændingen.
Det er ikke sikkert det lykkes første gang da tiderne skal overholdes.
racingdog
SLS-AMG skrev:http://www.youtube.com/watch?v=QJzV0oXlUFE
Godt nok på engelsk.
jeg takker, opgaven er løst , mv.
